Analog Output Modes
I am working on getting a test station setup for people at my company to play around with.
I have a DVC6200 Fischer control valve connected to the system via analog input (M-series input card and controller) which we are trying to automate in some sense. The valve does have power and air, and the control wiring appears to be correct (we are able to connect to the valve in AMS Device Manager and Valve Link and stroke it, etc).
But when we configure in DeltaV 12.3 we are having problems.  We made a new control module, assigned it to the controller, and then added an AO block, referencing the actual channel that the valve is on.  When we downloaded and went online, we couldn't get the block to go into any mode besides IMAN, and we are unable to drive the output.
We also tried linking to a PID block with a simulated input (planning on putting it in Manual mode and driving the output anyways), and the same thing happened-- all blocks are stuck in IMAN and we can't control.
I know I'm missing something stupid here... any help would be appreciated.
Thanks
