Hi, has anyone any experience using the DeltaV Excel Add-in to AUTOMATICALLY write values to a module? without having to click the manual update button in the menu bar? if so I would be interested in seeing your vbscript. I've copy and modified the DeltaV Excel Add-in vba code and am having some intermittent issues.
1) A message about having no time interval set, so a default of 0 will be used.
2) A message about having no cells selected that contain DeltaV write functions. I seem to get this if I save my excel spread sheet with a range a cells selected that don't contain the DeltaV write function.
In reply to Pierre:
In reply to Lun.Raznik:
In reply to timalg:
This is pretty old system!
For posting with image, click on "Use rich formatting". Once in the new editor, do Insert | Insert Image/Video/File.
Can you please check if you have macro disabled? Also, are you running Excel on DeltaV station?
By the way, what verion of Excel are you using?
Hi all
In old DeltaV Versions it was almost easy to "ack" the deltav Write functions in deltav.XLA ( and it works fine if you select all cells of the sheet including the time interval cell)
As it was a big safety hole ( wrong data can be written by inadvertance by any excel sheet , and create unmanaged command on process) Emerson decide to reenforced the security of addin to avoid automatic write functions.
In most of the case to build a report you don't need to write into DeltaV.
On new version of DeltaV ( from version 12 if I remember) there a very usefull tools called Excel reporter, which allow to get data from historian, with a wizzard to create scheduled tasks for automatic report. ( you can also create a button on HMI to run the report on demand)
Depending of the version, DeltaV excel reporter is located directly on DeltaV Bon folder or on deltaV DVD ( disk 1 if I remember well)
In reply to LaurentB:
