how can i convert two word to one dword?
Lars
Do you mean create a 32-bit unsigned integer with 16-bit integer A for bits 1-16 and 16-bit integer B for bits 17-32?
Use a calc block to roll 16-bit Integer B by 16 bits (ROTL) then add it to integer A.
When doing calculations on these 16 and 32 bit integers, make sure to store all values to parameters of the proper data type to avoid precision loss caused by casting to the wrong data type, like floating point.
In reply to Brent Hamilton:
