CHARM Baseplate
20 Aug 2020 7:14 PM
TPatterson
20 Aug 2020 7:07 PM
OPC error in Process History View
shadow_light
19 Aug 2020 2:47 PM
Valve CM Faceplate
John Rezabek
18 Aug 2020 9:45 PM
Splitter block "configuration symmetry" advice / discussion
18 Aug 2020 9:16 PM
Provox 120 VAC I/O to S-Series Mass Term Block
Charms Baseplate Cables- Do I need both?
DeltaV Electronic Marshalling now includes native DO Solenoid Valve CHARMs with the ASCO 580 CHARM node
CHARMS
Charm
Virtual CHARM
CHARM Baseplate
I have replaced a charm baseplate with a new one.
But when I mount the DI CHARM on the new baseplate, all the channels (DI 24Vdc low side) becomes active whereas the channels are not wired to the field device (dry contact).
Could you help me to solve this problem?
Best regards
Yoro SIDIBE |
Chef Service
Electricité & Régulation
SUCRIVOIRE | UAI Borotou |
BP 100 KORO
M: +225 07 07 21 78
E: sidibe@sucborotou.ci.
