HI,
I am looking for a bit of help trying to decipher where particular security settings are set specifically with prompts.
I have the scenario where i am issuing a prompt and setting REQDATA1 and REQDATA2 to TRUE, thus requiring confirmation and verification for said prompt.
I understand that REQDATA1 is considered to be the confirm and REQDATA2 to be the verify user identification.
I believe that the user lock ACTION_VERIFY is considered to be a SUPERVISOR key used for prompt verification.
I can't however find any detail explaining where the REQDATA1 and REQDATA2 are set up. How can i show or prove that the REQDATA2 is actually a supervisor requirement to answer the prompt?
Any help would be great.
Stephen
In reply to superstec:
The REQDATA1-5 and REQUEST work together.
Say you want to send a car to get bananas and Stella from the grocery store. You can do it two ways.
Way #1
REQUEST = send a car (i.e. 3200)
REQDATA1 = get bananas and Stella (i.e. 1)
REQDATA2 = getting carded to confirm purchase (i.e. 1)
REQDATA3 = friend in the car to verify you got it all (i.e. 1)
Way #2
REQUEST = send a car to get bananas and Stella (i.e. 3201)
REQDATA1 = getting carded to confirm purchase (i.e. 1)
REQDATA2 = friend in the car to verify you got it all (i.e. 1)
Either way, you're sending a car to get bananas and Stella from the grocery store (i.e. Batch Executive) that'll require getting carded and a friend making sure you got everything. The REQDATA specifics aren't as important as the main objective.
BATCH_ACK_PROMPT is tied to getting carded. Since the person going has the right already to get it, the confirmation is just to verify some 15 y/o didn't get the list (i.e. DeltaV station logged on but someone else in the control room that doesn't have that right to acknowledge prompts is in front of the screen).
BATCH_ACTION_VERIFY is tied to a 15 y/o checking. This action can be the driver as well if that option is enabled, but typically want it to be someone else that is a master at checking bananas and Stella. The verifier might not have the right to do the action, but have a great skill at checking groceries.
BATCH_HOLD, BATCH_STOP, BATCH_RESTART, BATCH_START, etc. are different function security locks. BATCH_ACK_PROMPT is tied to answering prompts through request codes, so the confirmer would have to have BATCH_ACK_PROMPT assigned key. The confirmer for all the other tick boxes would need to have the user key that each action's (i.e. start/hold/restart/abort) functional security lock assignment. The BATCH_ACTION_VERIFY is tied to verifying any actions (i.e. prompts/hold/stop/restart, etc). This could be a supervisor that doesn't have the right to answer prompts/hold/abort batches, but can verify what is going to happen next based on the production schedule.
That's how I usually understand how all that works.
