Am facing problem when i remote login my proplus machine (server 2008 delta v 11.3) am not able to open deltav operate .As soon as as i log in i get an error Ifix system not started and error no.2147212799(80042201). Folks any idea about this situation ???
In reply to AdrianOffield:
i closed workspace in local and tried to connect remotely same error is popping up
In reply to bobgally:
Try "MSTSC /console". Only 1 session is allowed with this.
Did you install "terminal server role" after or before installing DeltaV? If after, then you may need to re-run workstation configuration.
In reply to amodbobade:
Please refer this problem the Global Service to assistance. They will be able to help you troubleshoot the issue.
