I'm trying document STATE_MASKS configuration for a DC block, and was wondering what the parameter extension is to display this as a value, instead of having to nest tables of checked/unchecked/grayed in my design spec. Similar to how you can use .CV to define an option bitstring as a value.
You can use:
MODULE/DC1/STATE_MASKS.PASSIN
MODULE/DC1/STATE_MASKS.PASSOUT
MODULE/DC1/STATE_MASKS.ACT1IN
MODULE/DC1/STATE_MASKS.ACT1OUT
MODULE/DC1/STATE_MASKS.ACT2IN
MODULE/DC1/STATE_MASKS.ACT2OUT
The value will be in binary bit format to produce integer number in this format
awbxcydz where:
a=Fourth Ignore - 1 is Ignored
w=Fourth Value - 1 is checked, 0 is unchecked
b=Third Ignore - 1 is Ignored
x=Third Value - 1 is checked, 0 is unchecked
c=Second Ignore - 1 is Ignored
y=Second Value - 1 is checked, 0 is unchecked
d=First Ignore - 1 is Ignored
z=First Value - 1 is checked, 0 is unchecked
So if you had an input mask for passive of second unchecked and first checked and rest ignored...you would have 169.
Unforfulately you can't see these values from Explorer or Control Studio so I am not sure how you will be using this with your design spec unless you just document the above.
Matt
In reply to Matt Stoner:
Thanks Matt. That's a huge help. Mostly I'm just using these values to make my design docs neater/more script friendly. I think listing these as values instead of checkbox grids within a spreadsheet is better.
I ran into a hiccup with ACT2.IN and ACT2.OUT - the values for them are 32938 (corresponds to 10000000 10101010). I'm thinking the leading 8 bits have to do with the "Use active 2" checkbox? This particular block doesn't use Active2 - is there a parameter extension to specify this, or is it reflected in the ACT2.IN and ACT2.OUT values?
In reply to Phil L:
Yeah I forgot about that check box....the 16th Bit says if Active 2 is Not Being Used on both IN and OUT.
So if you are NOT used Active 2, you will add 32768 (16th bit is set).
If you are using Active 2, that bit will not be set and the original table is correct.
We usually provide design docs through export files. When you bulk export these fields you get
1's, and 0's, and X's (e.g. 01XX) to represent enabled, disabled, and disregard (grayed out) for the 4 inputs/outputs
It sounds like your trying to create documents using real-time data.
We're just modifying an existing class to make the DC statemask configurable. I wanted to label the design doc columns with the appropriate parameter extension, and wasn't sure what it was.
Thanks all for the help.
