FRSZ syntax
I get a VB error 13(D) when I execute frszOpenTagForm Me. This is a Type mismatch error. What is the syntax for this command? I can't find it in any help screens.
  • I'm getting also this error but on frszTagOpenForm Me, I guess a typo? Did you find the solution?
    I'm getting this error when clicking on the Tag Search Utility button in the default toolbar. DeltaV v11.3.1 Build 4263
  • The tag search utility looks through the modt.scr file in the download directory to perform the search. If the description of any of the modules contains an apostrophe, the (parsing character for defining attributes) or any other 'illegal' characters, you'll get errors. Perhaps this is what you are describing?.
    Sir, you're the winner! Thanks a lot!
    After finding that the MODT.SCR file is a text file, I was able to narrow it down to the offensive description. Two thirds of all the module showed up in the tag search utility, so it was only a matter of opening this file in notepad and trying the module name until I found the one who was not listed in the utility.
    It was the module description "PRESSION DOUCHE RELEASE\COATING". The problem was not caused by an accented character like we have a lot in french, it was by a backslash :) Switched to a slash, downloaded all the stations and it works like a charm.
