Is theer any size limitation for Fds file (Dynamo Set in deltav operate)? I was adding some modules in FDS where it prompted for Memory Violation.
I've never run across a size limit but I think everyone who works with DeltaV Operate has come across Memory Violations in Configure mode. It was probably just a coincidence that you were working with the FDS file at the time. Did you restart Operate and try the same thing again?
