Updating value of Batch Input parameter in recipe ?
Hi everybody
I am curious about something.
Is it possible to modify the value of a control valve after the step is completed by adding an input batch parameter as the set point?
I mean Batch read the given parameter by Operator on the relevant step, then it became inactive and in next step operator changes the value of set point on HMI page. Should I use sequence feedback to make the new changes or is the recipe capable of making them itself?
I would appreciate it if anybody could give me a hint.
M. Kalantari
  • Hi Dears,
  • In reply to Mahshid Kalantari:
