Message now showing parameter .CVS value in message on DV Live
I have a named set with values None (0), RO-1001 (1), RO-1002 (2), and RO-1003 (3), but in my message when I set the parameter with that named set and add the field of .CVS, it shows 'RO_skids:1' when I was expecting the named state to show up. If I use the .CV field instead of .CVS, it shows '1'. Any idea how to show the string value?
  • In reply to rhamlin:
    Check the download status of the controller the module is assigned to. You may need to download changed setup data.
