If you've been following my other threads.. lol.. after a reinstall of OS and DV. I had some issues. Those are mostly resolved and this one remains. My workstation which is just a tower running Windows 10 will not give the option to load DeltaV Live. It is grayed out on Flexlock. I have rerun workstation config on it after i did the proplus. It seems to be communicating fine. Proplus isn't mad at it. In DeltaV Live Diagnostics, it is also showing GOOD and READY. So, in workstation Management. I have made sure it is enabled of course, and I check ONLY using DeltaV Live. It's setup the same way as my Proplus which has no issues, aside from the use of a different Layout. So, I have toggled and saved and published the workstation in Workstation Management maybe a dozen times. Rebooted, etc. Still remains grayed out. I can go to the desktop and open Live but of course that isn't feasible for a number of reasons.
On 25 Apr 2024, at 02:42, Andre Dicaire <bounce-ADicaire@emersonexchange365.com> wrote:
<EE365_5F00_RGB_5F00_Standard_5F00_69x42-png_2D00_90x55-png> Update from Emerson Exchange 365 <4U2G7EF4S3IZ-jpg_2D00_70x70x2-jpg> Andre Dicaire I've seen this behavior but did not investigate as I don't lock the screens on my demo. I'll investigate on my system and let you know if I find something. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here. Flag this post as spam/abuse.
View online
