UPDATE: Solved. I remembered that the user account I was using was recently renamed. I guess it doesn't like that. So, i created a new user and i don't have the same issue with it. I will delete the old one.EDIT: This is not an issue unique to remote session. I cannot add a function block to a module even on a local session. IT has setup remote access through Cisco IoT Dashboard. I can use a remote desktop connection through the web app or I can connect to a VPN and use a native RDP session or VNC. No matter what method I connect with, Control Studio tells me that a user on a node is already editing the module in question. Well, yeah.. I"M THE USER!!! But, it treats it like someone else is doing it. and no, no one else is. There are no other active database connections. i've killed all connections, checked there are no other remote clients connected, etc. No one else even has the password, I'm the only one editing anything. I can still do graphics changes of course since multiple people can have displays open, i believe. Not sure where this issue is stemming from. I have informed IT to look into the Cisco side of things.
Thanks
In reply to Andre Dicaire:
