I am attempting to troubleshoot an analog output that is not working as expected. When I drive the output from the associated PID function block and check the output value using diagnostics I am finding a mismatch between the values. For example, when I set the PID output in manual to 0%, diagnostics tells me that the VALUE parameter for the AO channel is 4.64. 100% on the PID block output equates to 7.2 on the AO channel output.
What does the VALUE parameter that appears in diagnostics actually show? Is it the value in % of 4-20mA that the card is attempting to send to the field or is it a readback of what is actually being sent to the field? I have search books online but haven't found a clear explanation of what this parameter actually shows.
In reply to Rebecca Ferrell:
In reply to Conor McPhee:
