Preventing DeltaV Live Faceplate Resizing in Runtime
Is there a way to prevent faceplates from being resized during runtime? The only resizing options seem to be "Lock Aspect Ratio". The resizing also appears to be maintained after faceplates are closed and re-opened, needing a DeltaV Live restart to revert to default. How can we prevent these windows from being resized?
  • Hi Ryan,
    DeltaV Live is based on Scalable Vector Graphics (SVG) that will resize and adjust automatically, making the HMI truly resolution independent. But, you don't need to restart DeltaV Live to revert to default, you can use CTRL + Double-Click to quickly reset the size of displays and faceplates back to their default.
    I hope this helps!
    Camilo
    Camilo Fadul | DeltaV Solution Marketing Director
    https://www.linkedin.com/in/cfadul
