Hi All,
For our compressor testing we have configured DeltaV V14.3.1 (with PK controllers) in Dell Poweredge T340 system.
While configuring we found that we have to downgrade the server from 2019 to 2016. Once down that screen reolution got fixed at 1024 * 768 resolution. With installed again the graphic driver and was able to change the resolution to our project requirement (1280 * 1024).
Now even though the resolution is same, once loaded we found the text are being stretched. it also happens for all dynamo text as you see in attached picture.
Is there any workaround or update to fix this issue,
