Process History Data Export
Hello
Is there any way we can export the Process History Data (Alarms & Events) into an Excel file?
TIA
  • Should be able to select top left and lower right and copy to clipboard with cntl-C or edit copy, then you can paste into excel. We RDP into the PStation and it works doing it that way.
  • Process History View has an export function that will export the currently viewed data to a CSV format that can be opened in Excel.
    You could also look at setting up a SQL query to the Ejournal database to pull the data based on criteria defined in Excel.  But there are more steps involved including user security settings and cybersecurity concerns, and it is not supported, meaning, the GSC is unable to assist you to implement or troubleshoot.  You should contact your local service provider to help you design and implement something at this level.
  • In reply to s_brwn:
    Thank you.
  • In reply to Andre Dicaire:
    Thank you Andre. That helps.
