Hi all.
I am currently running version 11.5 AMS and cannot get a proper echo curve from Rosemount 5300 radars. It does not matter whether they are connected via a DeltaV control system or ROC, the result is generally the same.
If you see the screen shot below it is representative of all echo curves that we get. Note the large scale of the vertical axis, in the order of 200,000mV and the curve is showing below tank bottom. (All other values on the screen tend to be relatively representative, just not the curve)
We have checked
Has anyone come across this issue previously and/or have a solution for a fix?
Tried to attach screen shot again
In reply to Russ Muller:
In reply to a_lot_of_devices:
