license for interface between AMS and DeltaV
Hello everone.
I was wondering How can I load license for interface between AMS and DeltaV?
warmest thanks.
  • Hi Moeen,
    Hope are you are Safe & doing Good...
    What I understand from your query that you want license the AMS Device Manager to interface with DeltaV as field devices are connected to DeltaV.
    Hope my understanding is correct & based on that sharing below suggestion.
    Click on Windows start-->AMS Device Manager-->Licensing Wizard--> License AMS Device Manager Welcome window--> Next-->Enter Disk Serial Number & Computer Name if nor picked automatically-->Next-->Browse--> select license file stored on file path (C-->AMS-->Db-->License)-->select License file-->Next-->Validation process will happened internally--> Message-License Successfully installed--> means AMS Device Manager License successfully.
    To add interface of DeltaV follow below steps:
    Click on Windows start-->AMS Device Manager-->Network Configuration-->Network Configuration Window will appear-->Add-->Available all network component will display in another window-->Select DeltaV Network-->Install-->Next-->Name the Network as you desired-->Enter DeltaV ProPlus Name & DeltaV Admin Password-->Verify Computer Connection-->select all supported devices-->Advanced window High address to be entered if using PROVOX I/O (in this case Low & High Address "0"--> Finish--> will add network in Network Configuration.
    Hope this helps you.
    Take Care...Stay Safe
    Thanks & Regards,
    Tushar
