Discussions / Questions
How to command an EM from button in DeltaV Live
Life Sciences Discussions / Questions
Chris Amstutz
16 Jul 2012 2:53 PM
Federated Search, the ultimate multi-instance Syncade search tool
Chris Amstutz
13 Jul 2012 8:05 PM
Equipment Tracking and Electronic Log Books
Chris Amstutz
13 Jul 2012 12:37 PM
Syncade Language Engine Tips
Jim Cahill
11 Jul 2012 2:30 PM
Integrating Analyzers with Automation Systems in Life Sciences
Chris Amstutz
14 Jun 2012 3:05 PM
EMA Process Validation Guidance Draft Open for Comment
DeltaV Live layout issue
Combo box scripting in DeltaV Live
Saving the Environment While Saving Lives
What Do You Do for a Living?
How to convert an Integer to String in DeltaV
I'm struggling to create a new button in DV Live which functions to command multiple EMs to Idle. I'm using WriteAsync function as below. The A_COMMAND.CV parameter is a named set value. The Idle command has named set value of 1. The script verifies without errors but when I test it, the command is not written. I'm sure it's something to do with a type/field mismatch but I've tried so many combinations and can't get it to work.
DLSYS.WriteAsync("EM_Name/A_COMMAND.CV",1)
DeltaV Live
AutoEngineer1
4 Feb 2025 4:10 PM
Solved it finally. Writing string to string works so:
DLSYS.WriteAsync("EM_Name/A_COMMAND.CV.STR", 'Idle')
The single rather than double quotation tripped me up.
