Discussions / Questions
How to command an EM from button in DeltaV Live
Life Sciences Discussions / Questions
Jim Cahill
28 May 2012 1:03 PM
Emerson's Chris Amstutz on PAT & QbD
Chris Amstutz
15 Mar 2012 6:28 PM
In a Pinch with Disposables?
Chris Amstutz
24 Jan 2012 10:20 AM
Emerson will Be Presenting at the IFPAC International Forum in Baltimore
Chris Amstutz
13 Oct 2011 11:53 AM
TAKE THE SURVEY ON THE MYTHS OF THE NEW PROCESS VALIDATION GUIDANCE
Jim Cahill
27 Oct 2011 8:48 PM
How a Large Biotech Plant's DeltaV Systems Were Successfully Upgraded in One Day
DeltaV Live layout issue
Combo box scripting in DeltaV Live
Saving the Environment While Saving Lives
What Do You Do for a Living?
How to convert an Integer to String in DeltaV
I'm struggling to create a new button in DV Live which functions to command multiple EMs to Idle. I'm using WriteAsync function as below. The A_COMMAND.CV parameter is a named set value. The Idle command has named set value of 1. The script verifies without errors but when I test it, the command is not written. I'm sure it's something to do with a type/field mismatch but I've tried so many combinations and can't get it to work.
DLSYS.WriteAsync("EM_Name/A_COMMAND.CV",1)
DeltaV Live
AutoEngineer1
4 Feb 2025 4:10 PM
Solved it finally. Writing string to string works so:
DLSYS.WriteAsync("EM_Name/A_COMMAND.CV.STR", 'Idle')
The single rather than double quotation tripped me up.
