I am planning to install a combination of pressure regulators in series to maintain a constant flow rate for a constant load application. P1 --> (Regulator 1) ---> Pint -----(Regulator 2)----> P2.
P1 is fluctuating between 3 psig and 7 psig. Even if we don't have Regulator 1 installed, Regulator 2 will maintain P2. The load is a Kiln, with a constant gas requirement of 6440 SCFH.
As the regulator flow rate works on delta P, so what I am trying to do is maintain a constant delta P across Regulator 2 even if the P1 fluctuates.
Set P2 = 2.5 psig
Set P1 = 3 psig
I hope to see a constant flow rate to the load, even if the pressure P1 fluctuates.
Need input on that pleas.
In reply to Jeff_Welch:
In reply to Jawad Waheed:
In reply to Scott Sandy:
by the way we were planning to install 299H
