Dear Reader ,
I have got a basic question
Which part of flow meter is responsible for flow rate
Your reply appreciated
Thanks
Yunnus
In reply to leirbag:
In reply to Travis Stone:
In reply to Yunus Misbah:
Hi Yunus, You are correct. Different sensors have different ranges, and the sensor range is indicated in the model code. You can find Product Data Sheets (PDS) on Emerson's website for all of Emerson's flow meters, which detail the sensor capabilities, including pressure min/max, temperature min/max, flow min/max, etc. and lists the model code order information. This can be used to decode a model code on an existing device, or to build the model string for a new flowmeter you desire.
Emerson Sales can also help with this.
