Converting Emerson 700XA Gas Chromatograph Status Signals to Modbus Holding Registers
Dear Emerson Support
We have one 700XA Gas Chromatograph on which some of the boolean status are configured on Modbus Coil addressss (10000-19999). Some of the boolean status are as following:
No Sample Flow
Analyzer Failure
Low Carrier Pressure.
The flow computer that we have interfaced with this chromatograph supports only Holding Registers (40000-49999). Is it possible to change such status signals in Gas Chromatograph modbus map to Holding Registers?
  • Hello Shaiq Bashir,
    This can be done by changing the data type in the Modbus map from Boolean to Int , or create a new register of type int at an unused register address.
  • In reply to jamie marsden:
    Thanks Jamie, it did the job.
  • In reply to Shaiq Bashir:
    Great, Thank you for confirming.
  • hello you tell me how create pid loop
    thanks
    haroon dcs eng
    call iraq 07701012121
  • In reply to zazar:
    Hello Zazar, Please confirm what you mean by PID loop? Is this with regard to a Modbus function in our software?
