I'm new with ovation and I want to study my plant control sheet and control macros like dual valve, medium voltage motor. Any software to do it something like simulink maybe
Hi Abdul - Ovation does offer various power plant simulator solutions that can help train operators and also test control logic. Based on your question, my guess is that Ovation empirical simulation would be the best solution for what you need. It will generically model your plant by using the control system algorithms. Of course, I cannot determine what you may or may not already have installed on your Ovation system. As such, it might be worth a conversation with your local Ovation representative to compare what you have installed with what you might need.
I hope this gives you a little more insight.
