Migration CHARMS - Support
Has anyone come up with a mount or a jig for the DeltaV CHARM migration panels that will allow them to sit on top of a PROVOX termination panel?  We were looking for something smoother than standoff bolts.  Something that would allow easy access to the PROVOX panel for eventual removal.
Any Ideas?
  • I'd recommend you talk to Scott Ross in the exhibit hall while at Emerson Exchange.
    yes we have something, we´re going to use it, to a Provox to DeltaV migration, (charms).
    I hope it will be useful for you
  • In reply to Lucho:
    Looks good!
    The project I was on back then played with a bunch of designs.  In the end we went with something so simple it made us all laugh. Two 90 degree brackets and some small flat stock.
    $5 at Lowes or Home Depot, and it has an adjustable pivot point to get to the wires beneath, adjustable depth for positioning over cards with higher modules, and a big advantage when you go to install, is you can place it anywhere over the Provox rack.
    Wing nut is for quick loosening to tilt migration tray.
