how to enable WEF in DeltaV workstations and configure subscription server?
We are trying to setup a log server on the Emerson PIN network, we would like to collect DeltaV workstation/windows logs to be forwarded to this log server via a subscription server probably below the perimeter firewall.
Any help on how to enable windows event forwarder (WEF) on DeltaV workstations?
Appreciate your time in advance !
Best Regards,
Jai
  • Hi Jai,
    Emerson offers options to collect and forward events (including parsing of that information alongside potential network security monitoring as well) by means of our SIEM and NSM solutions (powered by McAfee).
    WEF requires WinRM which is disabled by DeltaV hardening following the CIS Benchmarks. This is a settings marked as NUC (not user customizable) in our hardening sheets and the impact to enable it would require a risk assessment related to cybersecurity posture of your system deployment.
    The SIEM option is fully supported by Emerson, and I always like to caution customers about the need to parse many of the events which are stored in the Windows events, but carry specifics to DeltaV that may not naturally translate easier on a foreign server. SIEM for DeltaV systems is always updated with the latest related information for DeltaV systems, hence the parsing work is reduced for you, and you have the advantage of embedded network security information if you choose to do so now or in the future.
    There is a "light" SIEM offering that may be suitable for your needs if indeed you want to use it as a simple collector and forwarder. Note that our SIEM provides the interfaces to be used as your full on management interface of logs coming from Windows nodes, network equipment, and ePO-generated events coming from Endpoint Security and Application Whitelisting applications you may have on your deployment.
    Sorry for the sales pitch, but may be worth considering if you haven't had a chance to review this option.
    Peixe
  • In reply to Alexandre Peixoto:
    Hi Peixe, Thanks for your quick response. Could you explain a bit more about the light SIEM. I would like to understand more about its functions on Event collection and forwarding.
  • In reply to Jai:
    Here is a link to help you with intro information: www.emerson.com/.../service-data-sheet-security-information-event-management-pss-en-1524026.pdf
    SIEM50 is what I referred to as a "light SIEM"
    Please reach out to me so I can connect you with the right team to support with any further information on that.
    Alexandre.Peixoto@Emerson.com
    Peixe
