For DeltaV Phase using PCSD template, in the start of RUN_LOGIC, it will check for the P_FIRST_PASS and P_TASK_PTR. In my testing, the logic was hold at P_TASK_PTR =3 and P_FIRST_PASS = TRUE.
If The logic was restarted, logic will go through the START step and bypass previous steps and back to steps related to P_TASK_PTR=3. This is absolutely correct.
We are testing what happens if we hold and restart the phase by changing P_FIRST_PASS = FALSE and keeping P_TASK_PTR=3, we discovered that the logic does not go back to the START step and the logic just get re-activated at the step where it stops. Why is this the case?
Shouldn't the logic start from the top of RUN_LOGIC and check the P_FIRST_PASS and P_TASK_PTR?
