I'm trying to use "multi-item select" for my operator to be able to choose what he wants an SFC to do. I'm using a Named Set Parameter "SP", names Idle = 0, Start-up = 1, Shutdown =2. When I try to use the data entry expert/multi-item select I can't get it to work properly. If I use the parameter "DVSYS.SEQ-5601/SP.F_CV", everything works, but the selector shows the values, not the names. If I change the parameter "DVSYS.SEQ-5601/SP.A_CV", the names are displayed properly in the Data entry expert, but when I select one, I get a "Bad value - Conversion Error".
I have tried every combination I can think of and can't get this to work. Any help would be greatly appreciated -- Thanks!
In reply to Maarten van der Waal:
