Graphics exporting - Active x controls
I am copying graphics from a running system to a simulation system, and my last challenge I hope, is the Unacknowledged Prompt Control embedded into many of the graphics.
When I copy the grf files with the control to the PIC directory on the target system, Operate run/configure states it cannot load the control (even though the control DVBCtrlPromptsList.dll is the same version on both source and target system, and is properly registered and referenced).
When I copy the grf files to the desktop, then open them in Operate Configure:  no problem.  When I switch to run time on the fly: no problem.  When I save the desktop grf to the PIC directory within Operate Configure, then open in run time: no problem.
I have many files and I do not want to have to manually work each file individually in this manner.  Is there a wizard or a routine to get the copied graphics to the pic directory to just accept the control without the additional effort?
I've run into this before but can't remember how I've solved it other than brute force.
Thanks!
