I'm trying to use a MPC (not MPCPro or MPCPlus, just the simple MPC function block), but I am running into a problem: the plant is reluctant to let me make a life-test with the MPC, so I decided to use a data file (.dat) to create the model: I followed the instructions to create and give format to the .dat file, but every time I'm trying to load the file I got an error message saying "This is not a valid DeltaV Model Predict data file." I honestly have no idea what could be wrong... Help pleas!!!
Hi CMendozal. It's tough to say what's wrong with the .dat file without seeing it, but the load data feature does work if formatted correctly. What I can suggest is switching to a MPCPro block. With MPCPro in DeltaV PredictPro, you can create a blank model by right clicking "Models" and selecting "new". Make sure that you have set your time to steady state appropriately first. Then select options -> expert mode, and you can manually enter model parameters (gain, time constant, deadtime, second order time constant). I'm not aware of any advantage at all of using the vintage MPC block over the MPCPro, so you should be fine.
In reply to Devin Marshman:
In reply to John Rezabek:
In reply to Lou Heavner:
In reply to fairchdm:
In reply to cmendozal:
