Greetings,
I am currently editing the "Primary Control Display" parameter, and I originally edited in 12 spaces (the default "blank") in order to leave the parameter blank as is standard for most parameters. Instead of resulting in an empty parameter, the Bulk Import resulted in "Primary Control Display" being filled with 12 spaces. I have tried subsequent imports (<>, a single space, nothing, etc.) and the import either overwrites the spaces with the text <>,<NULL>,etc. or leaves the spaces if I import using empty cells (no import error strangely). While this is not critical, and I can manually delete the spaces (~100 modules), I would like to know why this parameter behaves differently than usual, and if there is a way to overwrite an existing entry with a blank besides using 12 spaces.
In reply to Pieter Degier:
In reply to Chris Hoffpauir:
