Re
Thank you for your reply.
Normally I use watchit to browse to a specific parameter and change it online.
My concern is this case is different. for example:
Control Module 1:
If Condition X Then Variable X = 1
Control Module 2:
I Condition Y Then Variable X = 0
Control Module 3 - Composite Block 1:
If Condition Z Then Variable X = 0
I was hoping to get a cross reference table for Variable X:
Variable X:
- Changed in Control Module X (Expression)
- Changed in Control Module Y (Expression)
- Changed in Control Module Z (Expression)
The References option in the DeltaV Explorer only works for Control Modules and not Parameters inside them.
Can you please help ?
´Thank you in advance
