Recipe Parameter access
Hi All,
I'm trying to understand the recipe parameter and its use in the phase.
We are having requirement where i need to select the type of control (CFS or TMP) on TFF skid and this should be the recipe parameters. In BOI, operator will select Yes or NO, if Yes is selected then will be in CFS control and No in TMP control.
The query is can i read the status(named set value) of recipe parameter in Phase configuration and accordingly pass it down to EM ?
Karma doesn't have any menu, you get serve what you deserve.
