Has any had any success using the Dynamo Update utility to modify PCSD based Dynamos. My system is using v. 12.0.0. I have created a copy of the based dynamo into a new dynamo folder, made sure the original dynamo name and new dynamo name are the same, as well as changed the FRSDynamoInfo Initial Value and Current Value to reflect the same dynamo name and an updated version. For instance:
frsDynamoInfo InitialValue/CurrentValue:
Original: "Name: Horizontal Deviationbar Info, Version: 12.0.0"
New: "Name: Horizontal Deviationbar Info, Version: 12.0.1"
However, the dynamo expert does not work properly.
If a create a standard dynamo and name it something close to the naming convention the PCSD library uses, such as "Horizontal Deviationbar Info1, Version: 12.0.0" , create a new dynamo with the same name and a different version number and updated run the utility, the Dynamo updates as expect. Any thoughts?
In reply to nilesh.chordiya:
