I have a few hundred modules that we created 15 years ago (before "classes") which have an "Output Parameter" defined as a floating point. I want to change them all to "floating point with status". I am not a regular user of bulk edit and initially the FMT files I create do not seem to capture the parameter properties.
Is there a way to export the parameter properties so that they can be changed en masse and imported back into the configuration?
I am currently running DeltaV 13.3
John
