DelataV Operate
Hi there,
Question:  How to limit DeltaV operate on run mode to be shown on only two monitors.?
Status: I have currently four monitors, but it is inefficient to go back an fort between the applications.
Intention:  I would like to have my other monitors kept for other applications.
DeltaV version: 12.0
Learner
  • Hi Leaner,
    You need to modify .layout file to customize operator screens. Pls read in books online to see how you can do this.
    Zia
  • In reply to zrehman:
    Thanks, I will check this out.
  • DeltaV Operate is a Windows application. Unless you have it set to open full screen, you can resize the application window the same way you size Internet Explorer or Excel. The initial application size will be for the entire pixel count of your desktop, so you will have horizontal and/or vertical scroll bars when you shrink the application window, the same as Internet Explorer or Excel. The option to open the application in full screen mode is in the DeltaV Operate User Preferences.
  • In reply to Ben Bishop:
    Thank you. I'll look into it. but first I have to find the DeltaV Operate User Preferences. (I'm a bit new to DeltaV)
    Thank you for your help. it worked. awesome
