Redundant Controller - Standby
Hi All,
If I do an online change, does that change will reflect in the Standby controller or only in the Active controller?
My concern is that when the Active fails and let say there are a lot of online changes made, what happens after the switchover? would the online values still be there?
Gelo
  • Hi Gelo,
    As per my knowledge, it'll reflect in both controller. If one controller is fail also there is no problem, everything will run by with standby controller with changed online values.
    Venkatesh.G
  • In reply to venky9133:
    Yes, DeltaV's standard controller redundancy function will not require any additonal work to have both controllers synchronized.
  • Thanks Ventakesh and MC_CHOW for the response. really helpful
