SIS IOs Configuration
I convert the program from V10.3 to V12.3.I am facing problem while configuring the SIS IOs.
SIS Node -> I/O
Card Number is Available.How I can configure it and also Assign them to network?
Thanks
  • From Books Online:
    Configuring Logic Solvers
    The configuration of logic solvers (under the SIS Network) is identical to that used in the physical system.
    To create Logic Solvers:
    1. Select the SIS Network in DeltaV Explorer.
    2. Selecting New Logic Solver from the context menu.
    3. Configure the properties (Scan rate, secure parameter global publish, and high-density secure parameters) exactly as if you were configuring for the physical system.
    Hope that helps.
