Hi all,
Can anyone explain to me how the dc block handles fails.
I currently have a valve control using a dc block. The valve is in a group with other valves and a failure on itself or the other valves is an interlock on itself.
The problem i seem to be facing is this.
The fail alarm from interlock or any confirm time fail puts the dc block to the passive state. I have reset required selected in device ops but until the interlocks are clear i can not change the state from shutdown/interlocked to locked to allow the reset to work even though the dc block is now in the passive state.
The problem with this is that when i have a confirm time fail i also get the interlock from the failed valve. If i choose to ignore pv ie turn on accept_d i still cannot clear the fail alarm while the interlock is still active even though the valve is in the passive state.
Is there something i am missing in the DC block setup?
Thanks in advance
In reply to AdrianOffield:
In reply to gamella:
In reply to Matt Stoner:
