Dear all,
I have an issue with the Search Utility. When I click to the Search button on the DeltaV operate I got a popup message " Error Number: 5(5) Invalid procedure call or argument" , then I click "OK" it has another popup message "Error Number 9(9) Subscript out of range". Anyone knows what went wrong with the DeltaV workstation and how can I fix it? Thank in advance.
Lihn
You can look in the MODT.SCR file (don't edit it..it's in the DOWNLOAD folder). Sometimes it puts a return character for the faceplate, detail, and/or main picture. Scan through that and you'll see some of the modules are split into two lines. Write those modules down and what is referenced before the split in the lines, and rebind it DeltaV Explorer by searching for the file instead of typing it out.
In reply to Otto Von Steele:
Look for " ' " (single qoute) characters in control module´s description and remove it all, try to remove any symbol character in control module's description. However you should download and install the last deltav workstation update from your guardian support site, that should resolve this issue too.
In reply to Lucho:
Everyone,
This topic has been discussed before on this site: See the two following previous discussions:
community.emerson.com/.../2282.aspx
community.emerson.com/.../6885.aspx
The site search utility is a good way to discover if an issue has been described before.
