Combining aliases
I am trying to combine/concatenate two aliases. This seems to work in an expression:
You can see that the value is being correctly referenced and read. The problem is that the block has a "Readback failed" error and the status of its output is NoCommNUV.
Also, this path, if used in an External reference, does not give a value at all.
Could you tell me why this is? Do you have experience using more than one alias in one path?
Thank you,
Istvan
