I am trying to reference an alias ignore flag within an expression in order to determine whether my unit instance contains a module or not. I have tried a few different syntaxes to try and reference this parameter including what the BOL suggests: "you need to use the syntax /aliasname.IGN (with only one slash and no # signs)." However this expression does not parse when formatted that way. Does anyone have any experience with this problem?
The check to see if an alias is ignored on a Unit Class Instance is '/ALIASNAME.IGN' = TRUE
EM aliasing using Module blocks is a little different which is '/MODULEBLOCK/_IGNORE.CV' = TRUE.
In reply to Matt Stoner:
This is the suspect code. It is in an a condition block. I am just trying to check whether the alias is bound or not in the unit instance.
'/LIQUOR_2ND.IGN' ? ('//#LIQUOR_VLV#/DC1/PV_D.CV' != '_VLVNC_PV:CLOSED') :
('//#LIQUOR_VLV#/DC1/PV_D.CV' != '_VLVNC_PV:CLOSED' OR
'//#LIQUOR_2ND#/DC1/PV_D.CV' != '_VLVNC_PV:CLOSED')
Unresolved parameter: /LIQUOR_2ND.IGN
In reply to chip.burge:
Is this condition located in a phase or somewhere else?
If located somewhere other than a phase, you would use '//UNIT_TAG/LIQUOR_2ND.IGN'
So the condition is located in a control module class which supports the module block in the unit class. It would be nice to do this without having to change the code for each individual unit module created from the unit class.
When using a class-based module's alias' IGNORE field, the correct syntax is the '//^ notation. For example, 'PARAM1.CV' != '//^ALIAS1.IGN'. This differs from the syntax used in unit modules and their unit phases.
