What is the best way to move a configuration from one system to another? This would be from a test system to a soon-to-be production system.
Should I export/Import confguration, or backup/restore database?
Thank You,
Frank
I highly recommend using backup/restore over import/export. It is faster and less prone to errors or unexpected consequences.
Import/Export may be necessary to ensure that only legitimate (e.g. tested) code makes it to the production system.
When using backup/restore, the path to the file must match on both source and target systems. I use
\\localhost\dvdata
as the path, because regardless of file system architecture, all deltav systems will resolve this path.
Thank You Youssef.
