Controller Redundancy | MD+MQ | DeltaV 13.3.1
I am looking for some help in getting my redundant controller pair back into a redundant state.
I came across a pair of controllers where the secondary controller was showing as active and the primary one had a blinking standby light. (Both controllers are MD)
In DeltaV Diagnostics under Redundancy, I found the following details.
  • STBY: BAD
  • OInteg : BAD
  • PExist : YES
  • PAvail : NO
  • RedEn: YES
I assumed the controller had failed so I removed it and replaced it with a spare MQ.
I used the controller firmware utility to bring the MQ firmware up the the same as the MD one.
After this operation, I am back where I started.
The same status in DeltaV diagnostics and a blinking standby light on the new MQ controller.
Is there another step or something I can check?
