HART status "Device Range Span Too Small"
I have a MSA General Monitors S5000 gas detector connected to DV.  In the CM configuration it is an AI using "FIELD_VAL_PCT".  XD_SCALE is 0-100%, L_TYPE is Indirect, OUT_SCALE is 0-100 ppm.  The transmitter has a span of 0-100 ppm, and full range of 0-100 ppm.  The DeltaV DIagnostics is reporting "Device Range Span Too Small".  Any ideas how to clear this?
Don
