Hi All,
On a VCAT-enabled database, I recently updated the phase. When I simply saved the modifications in RUN_LOGIC and compared the results, something strange happened. which are listed below:
FAIL_MONITOR is likewise showing red, indicating that something has changed, but when opened, it revealed only a definition change difference, with no further changes visible in the difference.The same is true for HOLD_LOGIC and ABORT_LOGIC, except for the definition.
Does anyone have any clue what caused this change? I've done modifications before and moved them from development to qualified environment, but I've never seen anything like this.
Thank you in advance.
In reply to Matt Forbis:
