For some reason, recently I have started getting random floods of Module Errors and Modules status alarms, red boxes around the objects on the graphic and equipment shutting off. Is there a decoder ring to help interpret the Module Error and Module Status codes?
These come in and then about 30 secs later go inactive. The equipment is functional and has worked for 6 months or more. The devices are linked to DCS through and EIOC, Rockwell Stratix switch ,to the ENBT in a single ControlLogix PLC. All of my devices using the EIOC are effected and it appears to be different MCC sections.
In addition to the Error/Status decoder, are there any txt files or similar buried behind the curtain to see any additional info that might be driving these alarms?
Thanks in Advance-
Alarm Screen Process History View shows 1088
Mike Brannon // Project Manager Revere Control Systems
In reply to MICHAEL BRANNON:
In reply to Andre Dicaire:
In reply to Matt Forbis:
In reply to s_brwn:
