Hello everyone,
I am Shivanshu Patil from AISSMS IOIT, Pune. I am pursuing my Bachelor's Degree in Instrumentation and controls and for my final project, I am working on the Delta-V system. Basically, we are planning to interface the CSTR pilot plant with the Delta-v system but due to lack of expertise, I am not able to implement the MPC. I followed all the instructions mentioned in the Online-Books of DeltaV.
But after clicking the test process in DeltaV Predict I faced the following errors repeatedly:
I am not able to get solutions for these errors and If possible can anyone share steps for implementing an MPC using Delta-V Predict to overcome these errors.
Thank you in advance!!!
In reply to Lou Heavner:
Great comments from Lou! Note also for the MPC block, the input and outputs must be directly wired to the source as shown in the first diagram OR use the MPC Reference Function Block to connect to source or destination in module different from the one the MPC block is within. Make sure the mode used for the MPC mode in the MV block (e.g. AO or PID) is enabled.
In reply to James Beall:
