We have a project where we would like to install a couple Charms panels/enclosures in the field. By "field" I mean not in a climate controlled IO room or similar environment but outside in the process area. The enclosure would likely have a couple power supplies, network switches, redundant CIOCs and a few terminal bases with Analog/Discrete IO installed. I have seen the temperature specs on the charms hardware but would like to have some real world feedback as to people that have actually installed them in the field and what challenges or experiences they might have had. Assuming the panel is purchased correctly for the NEMA requirement and the temperature in the panel doesn't exceed 120-130 ambient, are there any other considerations?
Thanks in Advance
In reply to SimHogan:
